Legato626 - 94 blaze red mx-3 GS
Macen
Post by Macen »
Oh, sorry, my bad.
Black '93 GS-RL KL-DE
White '95 RX-7 Type R Bathurst
http://macen.nullnet.com
ovendenk
Post by ovendenk »
is it the front or the rear bolt that you can't remove?
if it's the rear, try removing the 3 17mm bolts instead and you'll have to use some sort of extension on the ratchet, but it's easier than the big 21mm nut. after you get the 3 back bolts, front bolt, stabilizer link, and ball joint, remove the control arm from under the car. then, put a 21mm socket and ratchet(and use an extension) on the last nut and use the car's underside to stop the control arm from rotating as you remove the nut. it's on there tight though. you may need to use your foot to stop it from sliding on the ground. ghetto, but effective.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
lakersfan1
Post by lakersfan1 »
Legato626 wrote:thanks!! =) ya that was easy as hell to do. just like a total of like 4 hours we were done.
But the bushings.... thats another battle for another day... I need my air tools for that fight.
You can't get it off with a 2 foot breaker bar? Mine weren't that hard to get off. :shrug:
lakersfan1
ovendenk wrote:is it the front or the rear bolt that you can't remove?
Isn't that the logical way to do it? Air tools wouldn't help if he was trying to do it the other way, because you can't get a socket of ANY size on that 21mm nut because of the chassis. You HAVE to take the three 17mm bolts out first and drop it.
Legato626
Post by Legato626 »
No the part I cannot get off is the damn sway bar link...
1994 Mazda MX-3 KL-ZE
ovendenk
Post by ovendenk »
on the end of the threaded section, you put an allen key. so, wrench on the nut and an allen key in the threaded section to stop it from turning. can't remember size of allen key though, sorry.
BADMX3
Post by BADMX3 »
i think the allen key is 5. I did mine today > really helped getting them off while the engine was out :)
mazdamx3sohc
Post by mazdamx3sohc »
nice work man, now will that magnaflow hi flow cat work on any mx3, like my 93 sohc?
Legato626
Post by Legato626 »
ya as long as the piping is 2.5 but you can get one in any size you want.
mazdamx3sohc
2.5 will slid over or inside the exhaust pipe and clamp up flush?
