Legato626 - 94 blaze red mx-3 GS
Legato626
Post by Legato626 »
Body: fixing my bumper / new CF hood
Suspention: front control arm bushings / new KYB strut mounts rear/front / KYB dust boots / Tokico HP blues / H&R sport springs
Engine: mazdaspeed engine mounts / poly inserts / light weight flywheel 9lb / new clutch / removal of A/C / light weight crank pulley / 67mm TB / new belts / OBX racing headers
Right now we almost have the engine pulled. I have the clutch flywheel poly engine mount inserts and control arm bushings already. All of this must be done before Apirl 15th! =)
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
Legato626
Post by Legato626 »
clutch came today!
Legato626
Post by Legato626 »
Operation Facelift :D
Just started sanding and puting the bondo on. This stuff is working great it! I never used bondo before but it is really coming along quick!
Before pic's
The first layer of bondo!
Engine mod update: Still waiting on the parts to show up at my door step but everything is going as planed!
93_4Banger
Post by 93_4Banger »
that bondo looks to thick bro i think thats gunna crack as soon as it flexes one tiny bit just a suggestion throught some fiberglass in there! but you could try and prove me wrong
Legato626
Post by Legato626 »
O its strong I pull on it a bit just to test it. That is just a little layer its a fine layer plus I do like 20 mins of sanding to get it really smooth up the edges. thats just after the second layer I have it down now and it took me 5 layers to get it smoothed to match the bumpers curves.
Legato626
Post by Legato626 »
Operation Facelift update
I have the middle filled in took 5 layers and sanding after each one to get it smooth with the body. Going to get a can of primor tonight so I can get that ready for paint. I am also starting to attack the easy cracks that are on each side. Going to order my air brush so I can paint it.
Legato626
Post by Legato626 »
I have it all sanded and got it primored and ready for paint.
Legato626
Post by Legato626 »
Update
I almost have all my stuff here is a pic of most of the stuff I ordered. I am still waiting for my front control arm bushings and mounts for corksport...
List:
4 new dust boots
tokico HP struts
H&R lowering springs
all 4 new mounts
new clutch slave cylinder
SS headers
Magnaflow high flow cat
hobbypete
Post by hobbypete »
FYI the high flow cat might not allow your car to pass an emission test for NOx, if required. I guess you probaly have an EGR system, but from personal experience, I can tell you that a high flow cat allows three times more NOx contaminants to pass through than are allowed under Ontario standards.
Legato626
Post by Legato626 »
Thats the fun part I live in North Dakota we dont have emissions!!! :lol:
hobbypete
Post by hobbypete »
Oh, you have them - you just don't know how bad! I'm going to move.
Legato626
Post by Legato626 »
no we dont need to take are cars in to get checked we dont have to stick stickers on are windows. Non of that we have here. The only thing i seen was that are exhaust places are not able to take off cat's but they can replace them. =)
Legato626
Post by Legato626 »
Update
Finaly got my front bushings from corksport witch I ordered at the beginningof this month.... But tonight I am going to go put my suspention on or get a start on it anyway.
Legato626 wrote:Update
Which bushings are those?
fieromx3
Post by fieromx3 »
hobbypete wrote:FYI the high flow cat might not allow your car to pass an emission test for NOx, if required. I guess you probaly have an EGR system, but from personal experience, I can tell you that a high flow cat allows three times more NOx contaminants to pass through than are allowed under Ontario standards.
thats weird cuz i put a high flow from magnaflow on my talon and it passed with flying colors
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
