mx3 v6 running rough
hi there im hoping some one can shed some light on this problem. my mx3 v6 has just started to run really rough under acceleration, it has a loss in power when you put your foot down and sounds almost like a hammer drill, but if you ease of the gas and slowly put your foot down it accelerates fine! The only mods i have done to the car so far are a k&n air filter and twin exhaust.
you should make sure you really got it good. before i got my CAI, i ghetto rigged it but it held up really well. first i wrapped a bunch of layers of saran wrap around it, then a bunch of layers of black tape -- and it still didn't hold up after a few months.
even a small hole is going to screw up the works, so make sure you really get it sealed up. i guess the way to test it is to spray carb or brake cleaner all over it and if the engine revs up, you're still leaking. given that you already said you had a problem with it, i still think thats probably where the problem lies
Another thing that helped me when my mx-3 was running rough. From the intake there is a hose that goes to the bottom overhead cam. Put an air breather on there instead and block that hose, because what happens is oil gets sucked up into the air intake which is no good because of the air fuel ratio. It helped me. My car runs great now but still doing the klze swap soon.
