klze is in but throttle is in he way.
from everything ive read so far the klze is supposed to go it mo prob. now that i have it siting in the mx3 the throttle body will NOT clear the brake resivor. what is everyone else doing to fix his problem???
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
- relisys_3200
- jschrauwen
Re: klze is in but throttle is in he way.
That everything you read was obviously not enough. Since you haven't complete your profile to the max anyone that answers this Q of yours will have to assume that you're in North America or drive a LHD MX. That said, the issue with the brake reservoir and the TB only comes into play when you get the MS8 ZE engine and not the Eunos800 ZE engine. This must be the 4th time I've posted this in 2 weeks. The MS8 ZE usues the straight neck (aka Long Neck) IM and has issues with bumping up against the brake master cylinder. Most LHD MX's opt for the Millennia IM for the ZE engine. But hey, had you sourced the Eunos800 ZE (J-Spec Millennia) it has the curved neck IM and there are no clearance issues to contend with. I made posts today and yesterday about this and this is well documented in numerous posts that are retrievable via a search function.oh-hell wrote:from everything ive read so far the klze is supposed to go it mo prob. now that i have it siting in the mx3 the throttle body will NOT clear the brake resivor. what is everyone else doing to fix his problem???
All is not lost for there are a select few that seem to have negotiated that obstacle. If Patdiesel is kind enough to divulge his secret, you may be in luck. cheers,
John
- XxantwawnxX
Or just buy a Millinia manifold.
ok i see. actually i bought this engine for my ford probe and it fit fine. not until i bought a second mx3 that needed an engine and decided to use my ze did i discover my new problem. as for the milienea what years should i be looking for and i understand the engine is a 2.3. is that true??
- solo_ryder
actually you'd have better luck on probetalk getting that IM all probe guys want the straight neck ZE IM so they will typically trade straight up curve neck for a straight neck
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
ok i have the old short neck IM from my original klde but how bad will it hurt the preformance of my engine? also just fyi im adding a turbo, will i be better off gutting the IM ?? also if i do i just disconect the vaccume lines and leave all the wiring just unplugged ??
- PATDIESEL
I won't tell how I did mine. Flam e all you want...
You should try and get a curved neck ZE manifold. They flow a bit better. A DE manifold will work, but from most I've seen you loose about 10 WHP. You could port match the DE intake to the ZE head and get a much better flow and probably not loose much if any HP.
As for boost and VRIS. You need to take the VRIS completely out, then plug the holes it leaves in the intake (just a few very small ones)
Otherwise the plates will bock airflow and you get less HP. Also, I've always worried that something will come loose and get sucked down stream. (probably wouldn't, but I'm the kind who would do it just b/c it saves my worrying)
hey thanks dude, but im still courious,,, if i port my IM at the head wont the insides of the IM or a least what you can see be just as resrictive? sounds to me like its going to be resrictive no mater what with the stock de IM. porting the last 3 inches cant help that much.
i figured how to get the straight neck but i dont have a ze so bleh
-hec
- MX3 GSR for dummies
Oh-hell, here's how I fit the straight neck! Read my post, it's the last one
http://www.mx-3.com/phpbb2/viewtopic.php?t=50227
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
