found millenia supercharger for klze, good or bad idea
anyone know. also i was wondering if anyone ever swapped im's with the motor still in. is it even possible?
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
It's been discussed many times, it's not a KLZE, but a a KJ-ZEM, 2.3L Miller-Cycle supercharged engine. There are 2 main issues with this engine, first is height, it's farily tall and you'll need to customise the hood, and secondly, it only comes in automatic, so their specilation if a manual will bolt up to it.
FYI, the KJ is designed around the supercharger, it's actually part in how that engine works, it's designed for efficienty, not a sports car. I believe they say it's suppose to give the the fuel economy of a 2.0L, while the power of a 3.0L. No one had attempted it as far as I know.
- johnnyb
Nd4SpdSe wrote:It's been discussed many times, it's not a KLZE, but a a KJ-ZEM, 2.3L Miller-Cycle supercharged engine. There are 2 main issues with this engine, first is height, it's farily tall and you'll need to customise the hood, and secondly, it only comes in automatic, so their specilation if a manual will bolt up to it.
I believe whats being asked is if it will bolt onto this persons klze not if the engine will fit.
Oops, my mistake
- atlantamx3
ya hats what i was asking. i need to replace the IM and figured it might be good to have, its selling for 75.00
