Holy merciless gaskets!
hgallegos915
Post by hgallegos915 »
hmm autozone wants 100 DOLLARS for valve cover gaksets..what are these made out off??? Flubber? was wondering if i can just simply use some gasket maker??
-hec
2fazed
Post by 2fazed »
Autozone only sells the complete kit, which is everything you need for the engine. If you want indivisual gaskets, your only hope is Mazda/Ford.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Steeb
Post by Steeb »
crazy! even the mazda dealer is cheaper than that.
PATDIESEL
Post by PATDIESEL »
There is some company that makes/sells just the gaskets. I've bought them from places other than Mazda and only got just the gasket.
Take a look around at places like rockauto.com, NAPA, Advance Auto Parts and other parts stores. You'll find them.
OH, any K series motor valve cover gasket will work, but they should have the same part number meaning that if it is available then it will show up for the MX-3 too.
Steeb
Post by Steeb »
u can pick up a full engine gasket set on ebay for like 100 bucks
fowljesse
Post by fowljesse »
GO TO O'RIELLEY'S! I got the V/C gasket set for... I think it was $50 (in Houston).
Slammed6
Post by Slammed6 »
Normal price is about $50 for both.
The reason y Autozone sells them for $100 is because it includes both valve cover gaskets, and all new bolts and grmmets for the valve covers.
galf
Post by galf »
check out ALTROM on google. these guys are suppliers to napa and such. You can't order direct but you can tell your friendly napa dealer to get item #xxx from them. Best quality, only JDM products for mazdas.
hgallegos915
woah i found out i had HUGE vacuum leak from the valve covers,, the gasket was destroyed..
-hec
Mazdaboyracer
Post by Mazdaboyracer »
Also check online at Ebay stores and look for a parts supplier there. Often you can get full sets, new and sealed, for far less than chain stores. I got a complete gasket kit for my ZE from Cada Ltd. for $125 shipped. Came with EVERYTHING!
