Oil in intake.....
Oil in intake.....
My car recently started to burn a little oil. I have the 2.5 probe GT engine. It seems that there is a TON of oil going into the intake, my filter has a little in it, and the mass air is a greasy mess on the inside. Is this normal? Is the PCV valve shot? Should I run a catch can? Could this be why the car started to use oil?
Can I take the line off of the intake tube, and pit a breather on it instead? Can I disconnect id from the manifold completely? I dont know what to do.
seems like abad pvc valve.
-hec
well sorta yes, burning oil usually means bad valve seals BUT oil in intake is usually a bad PVC valve..valve is supposed to keepo oil from going to your intake,. get an oil catch can. Usually engines do that when they start to wear.
-hec
- solo_ryder
- jschrauwen
There are posts with pics on the particlar subject. Covered quite well and extensively. Pics are quite good and recommend you also try Grants site for supplemental info.
http://www.eunos30x.com/
http://www.eunos30x.com/howtos/oilcatchcan/index.html
