Holly Crap!
mazdamx3sohc
Holly Crap!
there like there. waiting to be ordered......wow i want intercooler and all included. USE THIS SITE!!!!
http://www.jspecautosports.com/catalog_ ... rod_id=266
- Josh
not that bad of a deal. pretty good actually seeing as though you get everything you need other than the trans.
- PATDIESEL
For 1900 bucks that is a super rip. You can get a BPT for 850 and then a Haltch for another 1000 then a custom intercooler for 200 and piping (which you would need anyway) and have almost 100 more HP for 2200. That is about 300 bucks for 100HP. I'd pay that anyday for 100 HP.
mazdamx3sohc
- Josh
if your not looking to go balls to the walls and want to keep everything with MAZDA, its a pretty good deal. i have found the same thing for 1300, but on average its a good deal for a direct bolt up with no hassles for almost a 100hp increase. and all you have to do is buy a boost controller and you can knock another 60 to 70 hp from it. now rember the ecu is already tuned for boost.
mazdamx3sohc
breenmachine
I wouldn't be swapping this myself obviously because of this newbish question but if I wanted to buy the stuff for someone to do a swap for me, would this be ALL i needed? Like I could buy this and be good to go? Do you need to replace the transmission when you swap the engine?
And one more quick thing, I searched but couldn't find a specific answer because I didn't know exactly what to search for, Does the BPT swap work the same for the 4cyl SOHC and DOHC? For some reason I remember hearing it doesnt bolt up as easily when your swapping a DOHC.
mazdamx3sohc
you should check a little harder i was in like 3 of them, anyways if you have the sohc and you want a perfect running bp. get the motor, the wiring harness, the ecu cuz it will be a lot better then stock however stock will still work, and get a good clutch and the flywheel from the car you are taking the bp out. so basically just small stuff.
motor
harness
ecu
flywheel
you can keep your clutch just dont beat it, if you want to beat it (hopefully you will do this on the track and not the street) get another stronger clutch.
have a ball!...or two.
motor
harness
ecu
flywheel
- MechaManZero
Hey guys. I decided I might put mine under the knife for another AWD MX-3 conversion. Saw this and it reminded me does anyone else know if there is better deals and where I can get a whole rear diff setup also. I know my parts are prolly coming off a jdm 323 gtx cause i don't think the US has any AWD turbo 1.8 323s here.
- Limegreen mx-3
I did have my 88 323 GTX up for sale BUT nobody wanted it because it was a rolling chasis and the distance. I decided to keep it after all and get it up and running Not FOR SALE.
