HELP ME PLEASE ,93 MX-3 SE COOLANT ISSUE????
I have a 93 mx-3 se that the anti-freeze is bubling air up in the radiator when running and turning brownish like oil.I checked compression on all cyclenders and they are 120 even.IF you take the oil fill cap off when its running the motor stumbles and cuts right off,you can here what it sounds like sucking air in the valve cover when you remove the cap.
Could this be a intake gasket leak or something to do with the water pump,does run hot also.
I cant imagine its the head gasket as the compression is good,oil looks good and the plugs look good also.
HELP < HELP Please. tomlbby@verizon.net
Thanks, shows you how much I know about these cars.lakersfan1 wrote:Your compression is good? It's 120. That's horrible. Our engines should have 190psi. A rebuild is called for at 150psi. 120psi hasn't been 'good compression' since the 50's. I'd say it's 100% a head gasket/warped head/warped deck issue.
Head gasket a big chore on these?
Anyone wanna buy it?
- slimmyslim1420
Re: HELP ME PLEASE ,93 MX-3 SE COOLANT ISSUE????
My car always died if I took the oil cap off. I thought the K8 compression was a lot lower than 180 -190. I know a DE only has like 140-160. And a ZE 180-210.?bowtech1 wrote:I have a 93 mx-3 se that the anti-freeze is bubling air up in the radiator when running and turning brownish like oil.I checked compression on all cyclenders and they are 120 even.IF you take the oil fill cap off when its running the motor stumbles and cuts right off,you can here what it sounds like sucking air in the valve cover when you remove the cap.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
leak down test
how is that done?you need specialtools?
No. If a DE only had 160PSI, you'd want to replace that s---. Read the online shop manual. For K8, 193PSI is the new, from the factory compression. The minimum is 142, but If my compression was under 170, I'd tear it out and rebuild it again.slimmyslim1420 wrote: My car always died if I took the oil cap off. I thought the K8 compression was a lot lower than 180 -190. I know a DE only has like 140-160. And a ZE 180-210.?
- slimmyslim1420
So what should the average psi be for a used DE? And if a K8 has 193psi new what does a ZE have new?lakersfan1 wrote:No. If a DE only had 160PSI, you'd want to replace that shat. Read the online shop manual. For K8, 193PSI is the new, from the factory compression. The minimum is 142, but If my compression was under 170, I'd tear it out and rebuild it again.slimmyslim1420 wrote: My car always died if I took the oil cap off. I thought the K8 compression was a lot lower than 180 -190. I know a DE only has like 140-160. And a ZE 180-210.?
- Custom_V6_Limited_SE
The KL-DE is suppose to be 203 Psi NEW, and i believe the ZE was about 220 psi NEW
But i had my MX-6 KL-DE with 190 psi across all 6 and it has about 150,000 miles, and the last ZE i had had 240 psi in about 4 cylinders and 220 in the others...damn that engine was strong...lol. My friends ZE is 210 across all 6.
