HELP ME PLEASE ,93 MX-3 SE COOLANT ISSUE????
bowtech1
Post by bowtech1 »
I have a 93 mx-3 se that the anti-freeze is bubling air up in the radiator when running and turning brownish like oil.I checked compression on all cyclenders and they are 120 even.IF you take the oil fill cap off when its running the motor stumbles and cuts right off,you can here what it sounds like sucking air in the valve cover when you remove the cap.
Could this be a intake gasket leak or something to do with the water pump,does run hot also.
I cant imagine its the head gasket as the compression is good,oil looks good and the plugs look good also.
HELP < HELP Please. tomlbby@verizon.net
lakersfan1
Post by lakersfan1 »
Your compression is good? It's 120. That's horrible. Our engines should have 190psi. A rebuild is called for at 150psi. 120psi hasn't been 'good compression' since the 50's. I'd say it's 100% a head gasket/warped head/warped deck issue.
bowtech1
Post by bowtech1 »
lakersfan1 wrote:Your compression is good? It's 120. That's horrible. Our engines should have 190psi. A rebuild is called for at 150psi. 120psi hasn't been 'good compression' since the 50's. I'd say it's 100% a head gasket/warped head/warped deck issue.
Thanks, shows you how much I know about these cars.
Head gasket a big chore on these?
Anyone wanna buy it?
lakersfan1
The head gasket is a bit of work since it's a V6 with two heads. The head gaskets are also a little expensive because of the odd engine size. You'd almost be better off getting a KLDE off a Mazda 626 and swapping the whole engine out.
slimmyslim1420
Re: HELP ME PLEASE ,93 MX-3 SE COOLANT ISSUE????
Post by slimmyslim1420 »
bowtech1 wrote:I have a 93 mx-3 se that the anti-freeze is bubling air up in the radiator when running and turning brownish like oil.I checked compression on all cyclenders and they are 120 even.IF you take the oil fill cap off when its running the motor stumbles and cuts right off,you can here what it sounds like sucking air in the valve cover when you remove the cap.
My car always died if I took the oil cap off. I thought the K8 compression was a lot lower than 180 -190. I know a DE only has like 140-160. And a ZE 180-210.?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
bowtech1
oil cap
Post by bowtech1 »
Anyone else had this issue with theirs?
Im trying to avoid the head gasket.
Wino
Post by Wino »
Did you do a cylinder leak down test.?This will pinpoint where your leak is before ripping the motor apart.
bowtech1
leak down test
Post by bowtech1 »
how is that done?you need specialtools?
neutral
Post by neutral »
Image -Jim
bowtech1
thanks
Post by bowtech1 »
I found a 93 mazda with a automatic 4 cyclander my car is a v6 1.8 standard.will the motors swap out even though the 4 is an auto without much work.
lakersfan1
slimmyslim1420 wrote: My car always died if I took the oil cap off. I thought the K8 compression was a lot lower than 180 -190. I know a DE only has like 140-160. And a ZE 180-210.?
No. If a DE only had 160PSI, you'd want to replace that s---. Read the online shop manual. For K8, 193PSI is the new, from the factory compression. The minimum is 142, but If my compression was under 170, I'd tear it out and rebuild it again.
slimmyslim1420
No. If a DE only had 160PSI, you'd want to replace that shat. Read the online shop manual. For K8, 193PSI is the new, from the factory compression. The minimum is 142, but If my compression was under 170, I'd tear it out and rebuild it again.
So what should the average psi be for a used DE? And if a K8 has 193psi new what does a ZE have new?
Custom_V6_Limited_SE
Post by Custom_V6_Limited_SE »
For the ZE, I believe perfect compression is 210psi.
'93 MX-3 GS SE:My Mods
Slammed6
Post by Slammed6 »
The KL-DE is suppose to be 203 Psi NEW, and i believe the ZE was about 220 psi NEW
But i had my MX-6 KL-DE with 190 psi across all 6 and it has about 150,000 miles, and the last ZE i had had 240 psi in about 4 cylinders and 220 in the others...damn that engine was strong...lol. My friends ZE is 210 across all 6.
