Here are some in progress pics of the taillights I have been working on for some time now. They are rough as you can see and still need a bit more resin and a lot of sanding. I'm also puting up pics of the LED's I will be using and the non LED parts I will be using for reverse and turn signals.
LED taillight
Turn signals (yes I am using marker lights as turn signals and as reverse lights as they are 12 volt. Less output for reversing but I needed something to indicate to other drivers that I am reversing.)
Custom housing
Last edited by Urbanconcept on April 4th, 2006, 12:03 am, edited 2 times in total.
Friendship is like pissing your pants: Everyone can see it, but only you can feel its true warmth.
Nice cusotmer work.. on ly mx3 to ever have ur lights unique is nice.
-hec
Thanks man. Trust me, I want them finished asap too. I'm waiting to install my oem sideskirts and a new rear bumper all at the same time (saves on having to paint them seperately).
I sat down the other day and thought the whole lighting situation out again. Im going to be making some changes to what I originally planned. Im going to extend the signal and the reverse light housing parts out a tiny bit to accomodate the factory wiring and bulb (make them plug and play). The smaller bulbs just won't cut it as they are way too small and not enough light output. So what I'm going to do is use the cone shape from the smaller marker lights and custom mount a new housing piece that will fit the larger bulbs. I think it will be much better in the long run, not to mention the ease of not having to alter the existing harness for them lol.
