Anybody have any ideas what kind of boost a BPT puts out stock, and what that turbo is capable of putting out, and what other turbo is the easiest bolt up swap?
Thanks
Stock Boost on BPT motor????
NickIreson
JWMotorsports
The BPT turbo is a IHI VJ-20 and I believe stock wastegate pressure is set around 7-8psi stock. Not sure what peak compressor efficency is capable of, I'd guess around 280HP but the outlet temps. would be pretty high. The easiest bolt on upgrade is a Corksport offering. They remove the VJ-20 center cartridge, mill the exhaust housing, and then stuff a Garrett GT-25R (dual ball bearing CRS) with a custom compressor wheel and housing to match your HP goals. Back when I was looking into bolt on upgrades for the VJ-14 Derrick @ Corksport said the largest I could go would support around 400HP (Compressor Flow). If your looking to replace the OEM turbo and manifold look to Shady Motorworks for custom parts.
Mazdaracer
- Franko
They say 7-8 but mine was always a minimum of 10 and even more with no boost controller. I believe the actual gtx has a solenoid that controls the boost level so it might actually be that low in a gtx.. but it wont be when you swap.
- ryanlindenberg
yea mine seems to vary a little bit. usually it puts out about 12 psi. sometimes it will hit 14.
CARDOMAIN WITH UPDATED PICS
- Flinch
Stock psi
my best friend has a BPT in his mazda 323 hatchback and he is runing stock psi of 13, its hauls. He has done nothing to the moter other than droping it in the car, get this he is using a 13x15x2 sidmount intercooler.
