I searched alil but did not come up with anything in all the forced induction threads. I know the ZE has blueish caps and the K8 has a reddish brown or marron color, what about say a 95 millennia S injector? what color does it have, or any other characteristics that u can see that tell it apart. Reason being is that ijsut got a set of millennia S injectors but they look alot like my K8, there caps are maroonish in color cept the rail was a lil diff and the caps had a green dot in the center of the maroon.
anyone that can help , i appreciate it.
How to tell Millinia injectors from ZE or K8?
- XxantwawnxX
- relisys_3200
- XxantwawnxX
Thanx : )
