How to tell Millinia injectors from ZE or K8?
XxantwawnxX
Post by XxantwawnxX »
I searched alil but did not come up with anything in all the forced induction threads. I know the ZE has blueish caps and the K8 has a reddish brown or marron color, what about say a 95 millennia S injector? what color does it have, or any other characteristics that u can see that tell it apart. Reason being is that ijsut got a set of millennia S injectors but they look alot like my K8, there caps are maroonish in color cept the rail was a lil diff and the caps had a green dot in the center of the maroon.
anyone that can help , i appreciate it.
relisys_3200
Post by relisys_3200 »
The 95-99 Millenia S (KJ-ZEM) = 280cc (maroonish top w/white/greenish paint splotch)
The 00-02 Millenia S (KJ-ZEM) = 310cc (brownish color)
Brandon
1992 MX-3 GS-ZE
XxantwawnxX
Thanx : )
Return to “Forced Induction”
