opinions ideas advice
Hey whats everybody im a lil bit new to the the mx3 but Im no dummy when it comes to cars. i own a 02 eclipse v6 with a custom turbo kit. I have 94 mx3 which has a crack block (DOHC) and a blown tranny (its a auto). Now ive been searching a lil bit on what to do with it. I just want it to be a daily driver for now and when my other car is finish i will work on it. Now do you guys recommend just replacing the block and swapping it to a 5-speed or should i just do the BPT or B6T swap and swap the protege lx tranny over as well.
no replacement for displacement do a klde or klze its the same ammount of work cus u gotta change the engine harness to do a bp you need to get a few more parts to do a v6 swap
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
I hate that arguement; its soo flawed. 1 word makes what you said incorrect.max kl wrote:no replacement for displacement do a klde or klze its the same ammount of work cus u gotta change the engine harness to do a bp you need to get a few more parts to do a v6 swap
Rotary.
Oh and the b6 ~> KL swap is WAY MORE than a few parts and a harness.
GS + BP + T3 + 9lb flywheel - some dead weight = ![Wink ;)](./images/smilies/icon_wink.gif)
yeah i like that saying but i have a new one "theres no replacement for displacement unless you have a huge turbo"max kl wrote:no replacement for displacement do a klde or klze its the same ammount of work cus u gotta change the engine harness to do a bp you need to get a few more parts to do a v6 swap
Correct if im wrong but dont some people use there stock motors and take the manifolds off a 323 to bolt up a vj turbo to it and piece the rest of it. know i will have to some custom piping but that isnt a problem
- monty73741
the bp can be installed into the dohc with the stock harness with a haltek
what i would do is get a dohc & install a turbo from a b6t on it
jason
jason
Jason Danaher
Please Help Support MX-3.com
Swap wise its not really that bad, when you have to custom fabricated new mounts and make a new wiring harness for a car that is when things get a bit hairy.D323 wrote:I hate that arguement; its soo flawed. 1 word makes what you said incorrect.max kl wrote:no replacement for displacement do a klde or klze its the same ammount of work cus u gotta change the engine harness to do a bp you need to get a few more parts to do a v6 swap
Rotary.
Rotarys displacments are grossly misrepresented anyways, Given its not a standard piston driven system mazda got to pick how the displacment was measured. Why would they give the motor a high displacment? (this matters quite a bit in thier how market where cars are taxed on displacment)
Ever seen what happens when you use forced induction a high displacment motor? Its a whitty comback but its still flawed.6g72-T wrote:yeah i like that saying but i have a new one "theres no replacement for displacement unless you have a huge turbo"max kl wrote:no replacement for displacement do a klde or klze its the same ammount of work cus u gotta change the engine harness to do a bp you need to get a few more parts to do a v6 swap
Yeah you can use the 323 manifold, I dont frequent the forums anymore but people have gotten good results out of turboing the DOHC 1.6 although the stock manifold has a issue with the VICS.Correct if im wrong but dont some people use there stock motors and take the manifolds off a 323 to bolt up a vj turbo to it and piece the rest of it. know i will have to some custom piping but that isnt a problem
-torp.
I don't own a Mazda.
