oil temp gauge
NOTHING
oil temp gauge
Post by NOTHING »
wondering if anybodys installed an oil temp gauge on a v6 if so where did u put the temp sensor
jschrauwen
Re: oil temp gauge
Post by jschrauwen »
NOTHING wrote:wondering if anybodys installed an oil temp gauge on a v6 if so where did u put the temp sensor
I believe it would be in a similar manner to this;
*edited correction*
http://www.mx-3.com/phpbb2/viewtopic.ph ... 11&start=0
Last edited by jschrauwen on December 21st, 2005, 4:33 am, edited 1 time in total.
PATDIESEL
Post by PATDIESEL »
Your link J-Beef, bring me to the search page (input search paramters)
jschrauwen
PATDIESEL wrote:Your link J-Beef, bring me to the search page (input search paramters)
Sorry Pat, correction made.
NOTHING
Post by NOTHING »
an oil pressure gauge is different from an oil temp gauge all cars already have an oil pressure switch u can just use that fitting 2 install the new sensor, and the water temp gauge also has a fitting 2 install the sensor, but since our engines dont have an oil temp gauge i waswondering if anybody knew of a spot that has an oil fitting besides the oil pressure sensor switch
Vanished
Post by Vanished »
yeah its just above the oil pan a real b---- to get out. Mine was leaking so i had to replace it. I coudlnt' find the right wrench size and its so fricken crammed good luck.
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
jschrauwen
NOTHING wrote:all cars already have an oil pressure switch u can just use that fitting 2 install the new sensor
My point exactly - to piggy back with the use of a dual output adapter, an oil temp sensor.
slimmyslim1420
Post by slimmyslim1420 »
Where is the oil fitting located on the engine that runs to the oil light?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
jschrauwen
slimmyslim1420 wrote:Where is the oil fitting located on the engine that runs to the oil light?
Is it not in the link?
slimmyslim1420
Well one part says its on the back of the block. Then that guy said if the fitting was too long it would hit the a/c fan housing so that would mean it was on the front of the block. No one indicates exactly where it is. And from everyones different posts its kinda confusing. I haven't yet looked on my engine for it, though if I did I may be able to find it that way.
thanks, Damon
jschrauwen
By the oil filter/cooler, front of engine. That's the one referred to in the link. "Vanished", may be referring to a secondary access plug on the rear of the engine, but I've not seen one in the manual.
