Haltech and T3 Super 60 installed!
- Franko
I finally got pictures of the new turbo and haltech e6x in the car. I drove it a little today, just enough to go get gas and back. It was allright even though it isnt tuned worth a damn. I dont have a wideband yet plus its winter. Hurry up and get here summer! I cant wait to see what it pulls like.
What do you think guys?
Looks great Franko, cant wait to see some dyno numbers and 1/4miles times out of that new setup. How much boost are you looking at running?
Keep us posted.
Keep us posted.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- Franko
I was going to run 15 pounds or so. Ill have to see how far I can go with 91 octane since thats all we got here but Id say that 15 should be fine. Cars still a daily driver so its gotta be reliable.
WOW you also have an IBM thinkpad on your mx3! i got one..cept its for snes and nes roms lol and tv Nice
-hec
- papa roached
woo woo franko
- XxantwawnxX
Franko wrote:I havent driven it yet because damn winter has its claws dug in deep. So I have to wait like 3 or 4 months!!!!! Its horrible..
man, i cant imagine your pain.
- mitmaks
nice install, cant wait to see it when its tuned, what fun it is to ride...ops...getting off-topic here
