Where is the Idle Adjustment screw ?
Can someone post pics, please ?
Where is the Idle adjustment screw ?
- jaydog5678
- jaydog5678
It is on all TB on the 4cyl's.
Before you check the idle speed make sure that all accessories are off (ie, radio, heater, a/c, lights). With the engine warm and the cooling fan OFF, you can make your adjustment btwn 750-850 RPM with a flat head screw driver. Your ignition timing should be set at 9-11 BTDC first before you adjust.
The adjustment screw will be obvious on the TB.
- jaydog5678
