I asked a while back in another thread about the required gaskets and such for a ZE swap. Just from reading im pretty sure the gaskets are the same on all the k series engines. I came across this gasket kit?
I've never really heard anyone talk about kits before though, which is why im asking.
The site is http://www.importperformanceparts.net/ , click Mazda, then gaskets, then TOGA HP Gasket Sets, part # CGSMA15HP.
Opinions on this? will this even work? Too expensive? Any other major gaskets i'd need?
Thanks
Gasket Kits?
- babyblueMX3
why not get just a oem HG from mazda ? THey are strong enough let me tell you that !
RIP 400whp ZE-T MX-3
- jschrauwen
Just wanna confirm before I go ahead and buy this. It seems fairly cheap for a complete gasket set. I'd rather pay a bit more than have to phone around mazda/ford/whoever.
Located at http://www.autopartsgiant.com
Part# 09-01165
[Full Gasket Set] CR 9.2:1 75mm K8 24V Eng; DOHC; GS
Plz correct me if im wrong, but this gasket set will be fine for a ZE? This would also be all the gaskets i'd need correct? probably more than i'd really need?
Thanks a lot
Part# 09-01165
Thanks a lot
