temperature.
- den
temperature.
I just bought my mazda mx-3 1.8 v6 a month ago. I am a little worried coz my temperature always goes above half on the gauge, its is more like 3/4 of it. Is this normal? It never overheated yet since I got it. The temperature is like 12- 18 C now here in canada so I dont think it should go above half.
1992 Mazda MX-3 GS 5 speed
Reverse glow gauge, Custom CAI, Cross drilled rotors. Toucan front strut tower bar, Custom circular ground wires, Custom exhaust w/ stainless oval dual tip muffler, Custom blue turn indicator lights on gauge panel and switches, performance steering wheel, Pacesetter short shifter
i would say check your radiator..maybe its beginning to get clogged. Ive had friends mx3's do that. Ever since I got my all copper radiator from radiatorworld.com my temp in semmer never goes over half it even sits a little lower. In winder its the same. I guess this is controlled by the thermostat.. replace the thermostat..its regular maintenance anyway why not?
-hec
If you do what hgallegos915 says and are happy its not overheating, don't worry about it. The gauges aren't very accurate but more of an indicator than a true gauge - hence no temperature markings on it.
- den
Thanks a lot guys! Who needs a mechanic's expensive check-up when I got you guys to help. You guys are the best! This forum saves me a lot of money. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
