lllllll
- Aston Wards
- Aston Wards
- Aston Wards
- Aston Wards
Hmmm, i don't seem to be able to find a FAQ!
to get the codes, open the bonnet, disconnect the neg terminal for 20secs, depress the brake, near the firewall there is a lil diagnostics box, use a paper clip to jump the gnd and tat pins, switch the ignition on, the hold light should flash some codes, long flashes for the first #, short for the 2nd
There is an online manual on mx-3.com, the codes are listed in the auto section
![Embarassed :oops:](./images/smilies/icon_redface.gif)
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
![Image](http://i2.photobucket.com/albums/y20/ViciousZ32/carbanner.jpg)
It happens to so many mx-3 owners on here you probly wouldnt be able to count them all. Make sure your tranny is not OVERFILLED... As i can remember there are 2 notches in the dip stick, the higher two notches indicate Full and fill in the HOT zone, and the bottom two are for checking when the engine is cold. I would start the car and let it idle for a bit get it warmed up. But it usually means the tranny is in the trunk (or hatch) ..get a manual gearbox it will treat you better and last longer.
94' MX3 GS atx
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
2000 kawasaki kx 500 MX
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
