dash swap done
dash swap done
hey i just done a dash swap this weekend. here are pictures! if someone needs help on doing this swap soon i could help cause its all fresh in my mind
hgallegos915
wow you make it lookm easier that it looks.
-hec
Juans_93_MX3
musta been a 1000 screws
- MX-3 Money
the job isnt that hard, i just had to grind 2 spots on the 93 frame and cut out a small plastic square under the dash to make it fit. all the bolts goes in and 2 tie wraps on each side of the dash because of the spots grinded
honestly i didnt take the time to fit the tubing for the round vents on each sides because i will swap BPT this winter and im gonna put guages on the driver's side and I never use front vents even during winter
yes there's alot of dust!
another problem is the wiring harness, you have to modify it to plug everything
spent a night doing this
nice swap dude
happy to see that ur keeping ur mx!
BooYaH Screaming Team
http://solo.monchar.com -> 15,871@88,5MPH -> Top speed 230km/h
http://stuart.monchar.com -> building in progress
RaVeR 4 life BabY!
got a Protege 1.8 SOHC 4x4 for winter ^^
RaVeR 4 life BabY!
What I drive: A Cybertronian disguised in the form of a Creek Blue Mica 95 MX-3 GS.
Long term goal: Fabricating a new transformation cog!
- mitmaks
nice job
-Jim
