Distributor Mod.
lastkiwi
Dist. Mod
Post by lastkiwi »
KILLERPICKLE,
What I am asking is this:- When you cut the wire , is the wire from the HEI now going into the LOOM or into the DIST Might seem like a dumb question but its better to be sure than sorry.
Colin - down under
Colin ---- down under
accordionservices@xtra.co.nz
killerpickle
Post by killerpickle »
Into the loom. Ensure that the 6th wire does not go into the distributer - esentially by passing the HEI of the distributer. And yes, your right, much better to be sure than sorry.
Tom Alexander
chertel
Post by chertel »
My distributor is shot. Can I do this mod? I am not a mechanic but if I have a good diagram or instructions I can try.
lastkiwi
Dist Mod
Post by lastkiwi »
Anyone can do this MOD [ well almost ]
I was told the Dist. was shot so I did the Mod. & it works!
The circuit diagram - list of parts - & how to is on this Forum courtesy of Gro Harlem.
If you can't find it Email me & I'll send it.
Coin - down under
chertel
Post by chertel »
I found it under the v6 faq. Learned a lot, gro did an awsome job on that and his work helped me out a lot.
thanx.
chertel
Post by chertel »
Colin can you email me a copy of the dist. fix.
chrishertel96@msn.com
thanx
I want to print it out.
killerpickle
Yo,
Check out the frequently asked questions for the v6 and also remember about the 6th wire.
Tom Alexander
