searched but didnt find anything.
my charge light is comming on some times at idle and when i press the brake it comes on till i let off. and when i turn my blinker on it blinks with the blinker.
did a fuse go bad? or is my alterntor gone bad?
charge light
charge light
95 Eagle Talon Tsi - New Toy
92 Mazda MX-3 RS - probably selling
86 Mazda Rx-7 - motor blew going 145
86 1/2 Toyota Supra - pissed me off sold it
91 Taurus... SHO - died
- Tunes67
Classic symptom of pending alternator failure. Do yourself a favor and dont buy a remanufactured one from Autozone when you go to replace it.
Tunes67
Tunes67
- neutral
Re: charge light
My .02. Not fuse related & betcha the alt is fine, but your alt-belt probably needs more tension. The belt sounds as if not so loose as to slip/squeal but just loose enough that it only can run a higher elec load (like all lights PLUS brake lights, 27w ea I think) when your rpm's are up. At idle, loose belt = a battery drain condition coming into play.92rsmx-3 wrote:searched but didnt find anything. my charge light is comming on some times at idle and when i press the brake it comes on till i let off. and when i turn my blinker on it blinks with the blinker. did a fuse go bad? or is my alterntor gone bad?
Ck belt tension and adjust but don't overtighten it or can dmg the alt bearings. Rough rule of thumb (literally) is to put moderate thumb pressure against the centerpoint of the longest belt span and you should see 3/8" - 1/2" deflection on a used belt.
-Jim
ya thats what i did last weekend before i put my car all back together was tighten my belts cause i just replaced them and they were squeeking still. everything seems to be good except once yesterday they ssqueeked when i started it.
- neutral
Might need another adjustment. For some reason, the adjustment tolerance is very small on these cars. I had to do 2-3 adjustments about a week apart after putting on a new alt belt. Most cars only require one post-install adjustment and sometimes not even that.
If further belt adjustment doesn't work then agree w/Tunes 67, alternator may be wearing out. In that case check, or have someone check the output voltage under idle conditions.
-Jim
