19' RIMS on the MX-3?
- GregoryChristian
That's not bad, you should only be 1" larger in diameter than stock, which is only an effective .5" in relative to the car's chassis, so he could still stop it a fair bitcustommx3gtx wrote:19" rims will fit on a mx-3 with a little work i have 19"x8 axis spyders with 215/35/19 rubber on mine and ive had no problems
& theoretically you could fit up to a 24" rim on an mx3.
The stock wheel/tire combo diameter is 24.8" so if you can find a tire that only sticks out .8" on a 24" rim then get dem dubs y0.
Of course the smaller the tire's profile the ride degrades exponentially but this is just in theory.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Wow, so many opinions and so little info to help the guy out. I say go for it.
I think 17's look tiny on these cars(i'm used to big wheels on big cars though). 19's with rolled fenders would look pretty nice. Bolted some 18's on my mx before and had no problems like rubbing or anything, but decided on a brand new set of 17's for now. As for ride quality and "bumpiness" i can't see it being that much worse on 30 series tires as opposed to 40 series. Besides, its an mx-3, its not like it handles like its on rails anyways.
SOLD - 93 GS Custom intake, exhaust, phenolic spacers, port matching, front upper strut bar, 17" wheels, dragon body graphics, black/white interior, sound system, tints, altezza tails & 3rd brake altezza, g-force front
'94 Caprice - rolling fast and low on 20's along with some custom goodies
'86 Regal - Hydraulics, custom wheels, custom paint, shaved, phantom top, leather, power, and lots of chrome
'92 - New import project in the works, should be out in '09
wow, talk about proclaiming extreme ignorance!cashmoneyspeed wrote:Wow, so many opinions and so little info to help the guy out. I say go for it.
My MX3 sure handles like it is on rails, probably b/c I set the suspension up properly and use some nice sticky tires and lightweight rims.
Hell drive over here and i'll let you drive it and see for yourself...you'll take back that statement
DONATE TO MX-3.COM
DONATE TO MX-3.COM
What do they drive then?Chronicle-Rod wrote:"find me a 19" wheel & tire combo in 4x100mm that weighs less than my stock 32lb 15's and i'll give you 100 dollars. YOU WONT! you probably won't find one under 40 lbs.
32 vs 40+ lbs? thats a VERY SIGNIFICANT difference and will be noticeable.
If bling blingin down the road is worth the performance decrease then go for it. It ur car & money & choice."
Let's face it - if someone is THAT into performance that they'll worry about a 32 lb difference in overall weight, they're not driving an MX-3.
I have a Tracer station wagon and the fact that my current wheels weigh as much as they do brings a tear to my eye every time I think about it.
And its probably safe to say that you completely missed the point about wheel/tire weight. It's all unsprung, meaning it's not stationary in relation to the rest of the vehicle. The added weight due to a wheel is something like putting on a pair of 10 pound a piece sneakers before going for a jog.. doesn't sound like fun.. But strapping 20lbs to your back, that wouldn't be such a big deal.
Either way, it's extra weight that the engine must move. You put that extra weight in the trunk, in the passeger seat, on the hood or on the wheels, it's still attached to the car, and must move with it.
- atlantamx3
I actaully like the style of those rims. I still think tehy are ginormous.
A widebody kit, maybe even a more agressive kit would really help make the whole thing look not so out of place.
And it needs a big battle wing! but yea that car is minty looking otherwise
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- Flashpoint2
