Hey everyone, after spending about 3 hours looking at old threads i'm deciding to post, b/c this problem is a little strange. Here it is....also the car is completely stock, no ecu mods or anything strange!
1) the idle is jumping anywhere from 200 - 1000 rpm and sometimes stalls
2) car will no longer take off smoothly without riding the clutch hard in first and second gear, is extremely jerky (i feel like i don't know how to drive stick)
3) Today it was 28 degrees out and the car was idling at 3000 rpm (first time this problem happend)
I am hoping someone can get me started on the right direction, i did read some things about ivc and stuff...but i have no idea where that is or how to clean it. So in your suggestions can you please be speceific.
Thank you and you help is greatly appreciated!
v6 engine running like poop!
- mitmaks
probably cracks in your rubber intake hose
- Mazderati
My first guess would be the above responses. But what about a timing belt system related part? Could this cause similar symptoms?
96 GS, 17" Niche's, Falken 40's. Eibach springs, Tokico S/R struts, Ractive front & rear strutbars. Supertrapp exhaust, K & N intake. Soundstream Reference, JL & Eclipse audio.
Green means "Go", Yellow means, "Go Faster"!!
And after you check the intake tube for cracks, get some aerosol-spray carb cleaner and (with someone keepin it going with the gas-pedal, or you manually using the throttle cable on the TB) give it 1/3 a can worth. Try injecting it in one of the vacuum lines, and plug the other end with your finger/thumb so it wont stall...
When this thing hits 88mph, you're gonna see some serious TIHS...!
if you hold a piece of a hose to your ear and move the other end around all the vacuum hoses you can hear air leaking it'll intensify the noisse and you can find a leak if you have one.
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
