//questions???
MX3ze@7psi
//questions???
I just got done with my pipes and tested them on my ZE with out any fuel management except my 255 walbro fuel pump. I only took it around the block and it only hit 5psi for about one second. and it only boosted once because the pipes keep on blow off. Should it hurt the ZE much??? It only hit boost once. Oh and yeah it spooled up fairly quickly too. I mounted it in the front and not by the side. pix soon....
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
reaper of souls
MX3ze@7psi
well i was just wondering cause one of my buddies was using my cartech fmu so I couldn't use it and I just ran it with just the fuel pump. My greddy blow off valve was working good too. Thanks!
- jaydog5678
- ryanlindenberg
yep just watch the boost guage and listen for pinging and you will be fine.
CARDOMAIN WITH UPDATED PICS
- babyblueMX3
just don't do it again...you were running 5 psi on a ze with stock fuel injection...you're lucky nothin happened..well it was only for a second that's ok I guess..Just be carefull next time..because 45-50 psi on 5 psi on a ze could destroy it by running lean..
RIP 400whp ZE-T MX-3
MX3ze@7psi
Yeah not going to try it again. Do you think running just the 2025 cartech fmu and 255 walbro fuel pump will be enough fuel to run the ZE at 5psi or do I need somthing else? I know that megasquirt is the best way to go but I don't want to mess with all the wiring. My KF setup was with just the 2025 cartech fmu and lasted awhile before the injectors went out and blew.
- babyblueMX3
yeah sure cartech 2025 will do just fine..that's what I have now and it runs great..as soon as the break in finishes though I'm swaping to MS but not because the 2025 doesn't work good it's because I'm shooting for high boost and fmu's are not reliable up there
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
