problems with b6t
nos92mx3
problems with b6t
Post by nos92mx3 »
Well over the winter i replaced the head gasket and the turbo on my b6t reason being they were both no good. now it will not start, the cams are dead on i also have checked for the keyway probelms and found that none exist. ( i removed the pulleys and check the key way for cracks and sloppiness with the woodruff key and that checks out. Now i have gotten the car to fire but it only runs on 2 cylinders. so my next idea was to check the compression, with the engine cold they were all in the mid-low 130's. Im stumped
Any suggestions?
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
ertaisi
Post by ertaisi »
Shot in the dark here...have you messed with the distributor at all? Could running on 2 cylinders be caused by an incorrectly installed cap?
'95 RS: RIP
nos92mx3
Post by nos92mx3 »
yes i did mess with the disty but only after i discovered that it was only running on 2 cylinders. i then replaced both the cap and rotor to see if maybe that was the problem but was not
93' Rs-t BPT - Sold
Return to “Forced Induction”
