Disty swap problem...
Nallboy
Almost through with my swap... another problem.
When I put my K8 disty on the ZE, the cam timing is off. The best it'll go is about ten degrees retarded from where the original was. I have the capability to make it fit (ie. tigging it up), but only if it comes down to that. I don't want a retarded car... what did you gurus do?
Thanks,
-John
Thanks,
-John
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
Nallboy
C'mon, guys. I need some help here. I know someone's had to deal with this. Don't tell me your cars are all retarded...
Nallboy
Guess I'll bump for one more try... Did you guys even check yours?
Nallboy
Don't want to be rude, but I don't know what that means in regard to my problem. It's my distributor. Everyone says to use the K8 disty, but when I put it on my KL-ZE (it does fit) the cam timing's off by at least ten degrees. My mechanic (Uncle) verified it. I'm wondering if I need to "readjust" the part that connects to the block (not good with names), but I'd have to do some welding to get it where it needs to be. I can't think of any other way.Taras wrote:I ran KLY ECU in my ZE for over 4 years now and no problem. Your's doesn't fit?
- Aston Wards
yah deffinatly takes some playing around but it will fit.
ze or k8 disty both work
AH YES, I THINK I KNOW HOW TO FIGURE OUT WHATS WRONG... is this in advance timing or base timiing mode? if you got a small vac leak in advance timinig mode..then your timing will be throw off, make sure your'e in base timing mode. other then that check for anything that would cause you to advance your timing, like tps, coolent tempt, rpm, and such. ..
93' blue mx-3, klze curve neck, kl36ecu, all the upgrade possible/out turbo.
Pigman
How would the TPS affect timming?? (sorry, I'm all new to mazda's, coming from an LT1 350...)
My car idled like crap. got tired of it, cleaned out the TB, re-did intake, checked vacuums, it helped, but it still stalled and no balls, popping exhaust ect...
After I instaled everything bach, I installed the TPS fully tilted towards the front of the car and now it doesn't pop anymore, seems to run much better, but it still idles high, like 1500 when warm, and sometimes perfect at 7-800.
Can't seeem to get a normal idle, but it doesn't stall anymore.
Sorry for the hijack....I'm just pulling hair here!!! ...lol
R.I.P Dimes
Fool me once, shame on you!!!, fool me twice...shame on me!!!
