Master cylinder
Master cylinder
Is the master cylinder similar for all years of mx-3s? Can I put a 96 into my 92 and be ok?
Red 1992 Mx-3 GS, all stock.
- Tunes67
Likely they are the same, assuming the 96 wasnt equipped with ABS... Pretty sure the 92 didnt have ABS as standard.. might have been an option though. Basically.. if they look the same and all the connectors are in the same place.. I would give it a shot. But if there is ABS involved.. I'd just get a new or reman master cylinder.
Tunes67
Tunes67
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
The ABS and non ABS master cylinder is the same..
The 929 or 900 series is bigger in size and is a better buy
a much firmer brake pedal.....
- kiwi_MX3
Mac, i would say it would fit not a problem, as mazda seems to
have standard bolt hole pitching on the cylinder and brake booster
for all cars, as the 929 bolts into the RX's 3,4,5,7's and utes.
- jschrauwen
Whatever happened to making home-made gaskets. It was part of the ciriculum in Grade 9 Auto Shop. Had to make them for carbs. Am I dating myself? ...LOL
