F/S Everything you need to swap a BP into your MX-3
Alright, if you've read my other post on parting out my mx-3 you know what i've got. I'll include everything you need to swap this bp into your RS mx-3, wiring, ECU, mounts, ect.... The bare long block is out of a 97 Kia Sophia with under 30K miles, and being a 97, it has the solid lifters, the head is a BP05, all the externals, like manifolds, accessories, wiring harness, ECU and stuff are from a 92 Protege LX. The engine runs great it has tons of power, the only thing it needs are new valve guide seals, so it smokes for alittle in the morning when first started up, but then the rest of the day is fine, It compression tests out great(170psi per Cyl) so i know the rings are good. The tranny also is out of the 97 Kia with only 30K miles, has a 4.11:1 ratio and some sort of stock LSD, with 28 spline axles, which is bigger than you'll find in any Pro LX or a EGT, both axles are brand new Constant velocity shafts and are also included. I'll sell everything i've talked about in the description for $800 plus shipping, which i paid over a grand for just the longblock and the Tranny. I'll also just sell everything minus the tranny for $550, or just the tranny for $350. PM me if interested.
92 MX-3 1.8L DOHC BP, 17" Konig wheels, 2.5 exuast, custom CAI, inverted style carbon fiber hood, GT-Combat body kit.
