What is vics?
What is vics?
this may sound dumb... but im doin a BP swap and i dont even have a clue what vics are... apperantly i have to have it, and ive run searches on what it is but all i find is how to set it up... and i dont even know what it is... ive got BP out of a LX protege... with an ecu... any one care to feel me in on this?
92' BP
Charles-
Charles-
- Shady469
written by protejay from protegeclub.com:
"VICS = Variable Inertia Charging System
the intake manifold has 2 different paths - up until 5,000rpm the air is directed through longer, smaller diameter 'runners' to produce better torque. at 5,000 rpm, 4 butterfly valves open to route the air through shorter, larger diameter 'runners' to aid breathing for high-end horsepower."
the aforementioned butterfly valves are operated via a vacuum dash pot and a solenoid valve of sorts that regulates vaccum. Normally the valves are closed due to the vacuum of the intake manifold pulling on the dashpot, but when activated the ecu closes the solenoid valve and the dashpot is relieved of the vacuum, opening the butterfly valves.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Re: vics
Yeah as long as you have the right ECU and wiring harness it will be functioning unless there is a problem with the system otherwise. There is not much to see unless you tear down the manifold, although the vacum regulator and diaphram are externally visable.krishna wrote:so is all of this stuff already in the BP engine? i understand now how it works... and how to hook it up, but i dont even know what it looks like, or where it is for that matter.
VICS depends on what motor it is on for what RPM it opens. Numbers for when they really open are a bit sketchy to find accurate ones.
-torp.
I don't own a Mazda.
VICS
okay so this motor has the vics in it already? and i plan on using my stock wiring... is that a problem? i understand that ima have to wire up the vics, ill probly spend a freakin month tryin to figure that out, but will that work?Yeah as long as you have the right ECU and wiring harness it will be functioning unless there is a problem with the system otherwise. There is not much to see unless you tear down the manifold, although the vacum regulator and diaphram are externally visable.
92' BP
Charles-
Charles-
hi guys, new here from http://www.clubprotege.com/forum ..... altho i was quoted above when i used to go by 'protejay' ![Smile :)](./images/smilies/icon_smile.gif)
anyways for some in-depth info on VICS, what it does, and the differences in intake manifolds, check this link out:
http://www.clubprotege.com/forum/showthread.php?t=7445
dyno charts start near the bottom of page 2 and lots of pictures are on page 3 comparing the manifolds...
- papa roached
if you use your stock wiring, the VICS wont work but it will run
anyone know if i can use a 1994 stock rs computer to run vics properly?
BP POWERED MX-3
http://members.cardomain.com/bbprecidia
thanks b i guess that answers my question... peace
BP POWERED MX-3
