MX6 tranny the same as MX3???? ASAP
customescortturbo
does ANYONE know if the MX3 V6 Manual tranny solinoid is the same as the V6 MX6 tranny?? does anyone know if they are the same!
<img src="http://memimage.cardomain.net/member_im ... 06_189.jpg" alt=" - " />
SAY ELLOW TO MA LIO FREIND!!!!
VJ-20 J-spec Turbo
GTX J-spec Manifold
50 shot Dry Nitrous
Front mount intercooler
PSSSSTTTTCCCCHHHHUUUUU
VJ-20 J-spec Turbo
GTX J-spec Manifold
50 shot Dry Nitrous
- goldsberry1
Yeah they are pretty much the same the only real differance would be the gear ratios might be slightly different. but not so much it would be a hinderance.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
- mitmaks
yes itll bolt in but gear ratio is higher so you can go slightly faster with klze like 140+ mph
- masonholmes
1993 MX-3 ~ SE * 2.5L Swap'd
1993 RX-7 ~ Rotary Performance Built
1996 MX-5 ~ M-Edition * Topless, Daily Driver
masonholmes@hotmail.com
- papa roached
hes asking about the solinoid not the whole tranny
- masonholmes
Solenoid in the tranny? What does it do?
There are 2 switches in the tranny; Neutral and Backup. There's also a speed sensor. No solenoid as far as I know.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
