MX6 tranny the same as MX3???? ASAP
customescortturbo
Post by customescortturbo »
does ANYONE know if the MX3 V6 Manual tranny solinoid is the same as the V6 MX6 tranny?? does anyone know if they are the same!
<img src="http://memimage.cardomain.net/member_im ... 06_189.jpg" alt=" - " />
SAY ELLOW TO MA LIO FREIND!!!!
VJ-20 J-spec Turbo
GTX J-spec Manifold
50 shot Dry Nitrous
Front mount intercooler
PSSSSTTTTCCCCHHHHUUUUU
goldsberry1
Post by goldsberry1 »
Yeah they are pretty much the same the only real differance would be the gear ratios might be slightly different. but not so much it would be a hinderance.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
mitmaks
Post by mitmaks »
yes itll bolt in but gear ratio is higher so you can go slightly faster with klze like 140+ mph
masonholmes
Post by masonholmes »
1993 MX-3 ~ SE * 2.5L Swap'd
1993 RX-7 ~ Rotary Performance Built
1996 MX-5 ~ M-Edition * Topless, Daily Driver
masonholmes@hotmail.com
papa roached
Post by papa roached »
hes asking about the solinoid not the whole tranny
masonholmes
:freak:
IanL
Post by IanL »
Solenoid in the tranny? What does it do?
There are 2 switches in the tranny; Neutral and Backup. There's also a speed sensor. No solenoid as far as I know.
