Headlights
- Ricksmx3
Headlights
I finally got around to cleaning my headlights and wow they look so much better. I took magnaflow's advice in the apperance faq and went out and got Blue Magic plastic and plexiglass polish. It only took like five minutes a piece and now they look like glass.
2010 MazdaSpeed 3
mdavis
Re: Headlights
Mine always get fuzzy again in like a week... am I missing something?
GS-R SE
Fixin's
- Ricksmx3
Re: Headlights
It has been a litle over a week for me and they still look pefectly clear. What are u using?
2010 MazdaSpeed 3
- papa roached
Re: Headlights
i use blue magic, i have to redo mine every 2 weeks or so
Re: Headlights
same here, every couple of weeks i touch em up, not cuz they get bad. but if i stand in a certain light at at certain angle i'll see it comming back...or something...so i hit em again!
mdavis
Re: Headlights
I'm wondering if there is some sort of hard-coat you can apply after polishing to help preserve it...
GS-R SE
Fixin's
- Ricksmx3
Re: Headlights
I dont know i guess i just have to wait longer and see if they start to get foggy again.
2010 MazdaSpeed 3
Re: Headlights
GE Advanced Materials Hardcoat: AS4700
It's what is used on all of the new polycarb lens from automakers these days. Now that school is starting, I have more free time, I might take apart my headlight and re-hardcoat them to see how it turns out.
The reason that it turns yellow faster for some of you depends on the amount of UV that your car sees. If you are in the shade a lot, or park indoors, the polish effect will probably last longer.
