rs rear suspension question
do you rs folks have a the same sized rear stabilizer bar as us gs's?
- Casino
Re: rs rear suspension question
if you are talking about the lower tie bar we dont even have one.
or are u talking about something else ?
- millionflame
Clarify what you mean please.
Sway bar, or tie rod bar?
~ Millionflame (94 GS 120K)
stabilizer bar=sway bar. they are the same thing. strut tower bar is neither. some people get mixed up and call sway bars sway strut bars.
- jaydog5678
The RS uses a 19mm, front and back.
What does the rear bar measure on the GS??
The front GS is a 21mm, correct??
no clue. i wish i knew too. i think you may be right tho. does anyone know?
Strut tower bar is up top...The tie bar they refer to is down at axle level.
No?
No?
No Sig
Correct me if I'm wrong...
Tie rods up front...
Strut towers bars up top...
stabilizers out back on GS only...
There's a company that makes billet S-Bars for GS only!..
No Sig
It says for gs only but it will also work on an rs because you can take the lower tie bar and put it on an rs ou just need the longer bolts. Im pretty sure of this , not positive.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
so u guys dont have a rear stabilizer bar?
<small>[ December 07, 2003, 04:07 PM: Message edited by: Steeb ]</small>
- jaydog5678
You can use the SRD lower tie bar without using longer bolts. They're the same bolts as the GS, just without the factory tie bar.Originally posted by nos92mx3:
Yes, every Mx-3 has a rear stabilizer bar.Originally posted by Steeb:
is it the same size as a gs stabilizer bar? what size is it?
im glad one person can still tell a stabilizer bar from a tie/strut bar.
- jaydog5678
It's either going to be a 21mm or 19mm swaybar. I'm betting it's 21, but I'll double check some friend's GS's.
