Im sooo confused
Im sooo confused
Hello everyone, i baught a set of Jamex lowering springs from a guy and they are suppose to drop the car 1.75 inch in front and 2 inches in the back. i don't understand the whole camber thing. will i have a problem with that, and what will camber bolts do for me? please help. what is gonna happen to my tires? when i start drving it around. oo yeah one more thing i have coil over is it? where the springs go over the the struts. will this affect it?<p>[ April 02, 2003: Message edited by: z_x71 ]</p>
Keep smiling, It keeps people wondering what you are doing!
Re: Im sooo confused
what is gonna happen to my tires? when i start drving it around?
If you go and drive around with you're camber all screwed up, you're tires will not only wear out unevenly, they will also wear out very quickly.<p>i don't understand the whole camber thing. will i have a problem with that?
Yes. Make sure you get 4 camber bolts (one for each strut) and a 4-wheel alignment done AFTER you lower you're car.
<img src="http://members.rogers.com/zytariuk/images/mx-3.gif" alt=" - " />
1992 Mazda Mx-3 GS - Beige metallic
zytariuk's mx-3 page (updated June 12th, 2003)
ok great thanx i'll get some of those and a 4 wheel alignment done when i get it finished thanx a bunch
Let me know how you're alignment goes (with specs)! zytariuk@hotmail.com
a) if 1 camber bolt doesn't work, add another to each strut.<p>b) Camber doesn't wear out tires that fast, unless its VERY overdone.
-93 MR2
#129 E-stock
#129 E-stock
well how about with that drop that will be done, 1.75" in front and 2" in back?
what are the chamber bolts for? do you need them is you lower your car or are there ones on it already?
- millionflame
There are bolts there already but they're not very good since they don't move as much. It's better to get the thinner bolts for more adjustability.<p>~A
~ Millionflame (94 GS 120K)
where can i go to get chamber bolts and how much for them and how many should i pick up? 4?
- Andrew_Pakula
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by sta63:
where can i go to get chamber bolts and how much for them and how many should i pick up? 4?<hr></blockquote><p>I need to know this as well.
