Im sooo confused
z_x71
Im sooo confused
Post by z_x71 »
Hello everyone, i baught a set of Jamex lowering springs from a guy and they are suppose to drop the car 1.75 inch in front and 2 inches in the back. i don't understand the whole camber thing. will i have a problem with that, and what will camber bolts do for me? please help. what is gonna happen to my tires? when i start drving it around. oo yeah one more thing i have coil over is it? where the springs go over the the struts. will this affect it?<p>[ April 02, 2003: Message edited by: z_x71 ]</p>
Keep smiling, It keeps people wondering what you are doing!
zytariuk
Re: Im sooo confused
Post by zytariuk »
what is gonna happen to my tires? when i start drving it around?
If you go and drive around with you're camber all screwed up, you're tires will not only wear out unevenly, they will also wear out very quickly.<p>i don't understand the whole camber thing. will i have a problem with that?
Yes. Make sure you get 4 camber bolts (one for each strut) and a 4-wheel alignment done AFTER you lower you're car.
z_x71
Post by z_x71 »
ok great thanx i'll get some of those and a 4 wheel alignment done when i get it finished thanx a bunch
zytariuk
Post by zytariuk »
Let me know how you're alignment goes (with specs)! zytariuk@hotmail.com
ProtegeSTS
Post by ProtegeSTS »
a) if 1 camber bolt doesn't work, add another to each strut.<p>b) Camber doesn't wear out tires that fast, unless its VERY overdone.
-93 MR2
#129 E-stock
z_x71
Post by z_x71 »
well how about with that drop that will be done, 1.75" in front and 2" in back?
Guest
Post by Guest »
what are the chamber bolts for? do you need them is you lower your car or are there ones on it already?
millionflame
Post by millionflame »
There are bolts there already but they're not very good since they don't move as much. It's better to get the thinner bolts for more adjustability.<p>~A
~ Millionflame (94 GS 120K)
Guest
Post by Guest »
where can i go to get chamber bolts and how much for them and how many should i pick up? 4?
Andrew_Pakula
Post by Andrew_Pakula »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by sta63:
where can i go to get chamber bolts and how much for them and how many should i pick up? 4?<hr></blockquote><p>I need to know this as well.
ProtegeSTS
read the "good cheap setup" thread.
-93 MR2
#129 E-stock
