my built engine
- goldsberry1
my built engine
i'm so excited. my built engine came in today. it has forged piston and rods. and is the cleanest thing i've ever seen. i'm going to start puting it in this weekend. cant wait to get pictures for everyone. i bought it already built for 1800 from a guy from probetalk. just got to get my heads ported and the turbo on. cant wait.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
- babyblueMX3
Re: my built engine
whoa can't wait to see that too..
you know what brand the pistons and rod are ?
RIP 400whp ZE-T MX-3
- goldsberry1
Re: my built engine
if i rememeber correctly the pistons a weisco and the rods are from a millenia s. it came already built with a high flow oil pump in. completly assembled. just needs heads, timeing belt, cams and covers to run.
OsoSlo z28
Re: my built engine
are the rods new or reconditioned? what bearings did he use?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- goldsberry1
Re: my built engine
not sure about the bearings, but the rods were used if i could get on probetalk from here i would post a link. its new pistons in the stock bore. only like 60k on lower end before the new pistons. looks like the cylinders were honed. he said that there was new bearings through out the engine. does anyone know how to preoil the engine. like to spin the oil pump until the oil gets through the engine before i start it?
- BuGS
Re: my built engine
I was talking to a guy yesterday while my friend and I were swapping in a GOlf engine into his Rabbit and the guy said that he usually takes the plugs out and just hand cranks it untilt he oil filter is filled and the block is all oiled. It takes 10-15 mins but is way good on your engine. Starting it right up could ruin a lot of stuff....
- mitmaks
Re: my built engine
would like to see some dyno runs
Re: my built engine
10-15 mins?!!?!? i thought it was 10 -15 seconds
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- Zoso124
Re: my built engine
Just spin the crank, the Oil Pump is on the front of the crank, I assume he used assembly lube when putting it together. Before you start it up for the first time I would recommend taking out the plugs, yanking the fuel relays, and hitting the starter for 7-10 seconds. Don't go longer then that, you don't want you lower your battery too much or cook your starter.Originally posted by goldy1:
Mike Evans
Gone:
Gone:
