question about blow off valve
custommx3gtx
is it bad to run a bov with a maf?. if so why?
Re: question about blow off valve
ya cause it;'s letting out air that has been seen by the maf already
your run rich
get a bypass valve
your run rich
get a bypass valve
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
- cjthor
OR get a super afc that can compensate for the lost air!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
cjthor knows best:)
apexi and greddy have good systems for that
- Franko
So I have an safc, this means that I can get one of those saucy blow off valves that make all kinds of noise?
- babyblueMX3
that's why you place the bov before the vaf...in that order....compressor, bov, vaf, tbOriginally posted by Marlon:
your run rich
get a bypass valve
I've seen MANY set-up like this on probetalk
RIP 400whp ZE-T MX-3
marshmallow15
wont the car have the risk of shutting off with that setup? since if the maf doesn't get an air reading (because of the vented air via bov), then won't it cause the engine to shut off, especially at idle?Originally posted by babyblueMX3:
your run rich
get a bypass valve
- team slideways
- team slideways
JWMotorsports
I've been venting to the atmosphere for about 3 years now. It will be ok, it goes a little rich for a sec when it vents but if you close up the plug gap to around 32 and use a aftermarket coil (preferable an entire ignition system) it will burn off the excessive fuel and no harm done. I would recommend at least haveing a S-AFC though. P.S. I've been running 440cc injectors the whole time. Venting to the atmosphere hurts your performance a hair, but it was worth it for me just for the head turning noise! Shady can tell u....it TURNED heads!!! The power change is barely noticeable, like MAYBE a few hundreths of a second.
- Shady469
hey jeremy! i took the one off of the WRX and put it on mine. its ALOT louder than the turboxs.
but back to the question; you do run rich but as cj said it can be compensated for.
jeremy and i both have the HKS BOV and they sound very nice, and do the job very well. jeremy your gonna need two here pretty soon aren't you? or a race one...
lemme know next time you might be in town. i might be going to eastside one friday before Nopi for a test run.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
