anybody with a dohc 4cyl with ihi turbo?
anybody with a dohc 4cyl with ihi turbo? not the bpt but the stock dohc 1.6 4cyl motor turbocharged with a 323 or capri manifold and a ihi turbo
Re: anybody with a dohc 4cyl with ihi turbo?
jademx3 does. and hes put down almost 200hp untuned...so its not a bad option if you have a 94+ mx3, which I wish had
![Image](http://members.aol.com/march25/mx3sig.gif)
92 red rs
performance exhaust
zx2 struts and Eibach springs
turboed + stand alone when the cash is there
I am also running a 1994 MX3 1.6 DOHC with an IHI-VJ14 turbo running 8psi. Trust me it is definitely worth the investement. ![Smile :)](./images/smilies/icon_smile.gif)
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mx3dohc16:
<hr></blockquote><p>Do you have any hesitation problems with your setup? I posted that my like stalls if I try to accelerate to hard.
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
What do you have for fuel management?
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
I get slight hesitation on move off but I assume that is due to the retarted timing, I am looking to get a MSD boost timing master so that i can run standard timing again. <p>I am using 1.8 injectors, a Walbro 255 fuel pump and a Vortech FMU with 8:1 disk for fuel management.<p>I am also considering changing the IHI VJ14 turbo for a more powerful one, any there any turbo upgrades that will fit on my GTX manifold with little or no modifications for example a WRX turbo for instance.
I don't have anything yet, but I was planning on putting back in the S-AFC. I thought that was the problem to begin with, i.e. bad ground or something. I got the LX injectors and RX-7 Fuel pump, but no FMU or anything like that.
My MX-3 Website
My MX-3 Website
i have a protege that my cousin tolted and gave me. would it be worth swaping to the 1.8 and turboing that , or just turbo the 1.6
