FMIC or SMIC?
marshmallow15
Re: FMIC or SMIC?
a few inches? try a foot or two of extra tubing.<p>anyway, there's no real way to really know how much air that shroud can really flow unless its tested. or if you have a steam machine and an electric fan to make a mock-wind tunnel.
- team slideways
- team slideways
Re: FMIC or SMIC?
you tell me...<p>
<p>
<p>
Re: FMIC or SMIC?
Check the link in my sig, it has a lot of pics of the engine.
ltjrunner
Re: FMIC or SMIC?
about water-to-air ic....wouldnt taht drain away a notciable bit of power cycling the water to the ic? i know i discussed this with my father several times(he drives semi wich use a water-to-air) and he, and i must say from what was said i agree with him that power would be lossed from it...not to mention the beast of a set up.<p>about the top mount ic...some of the hood framing definitly would have to go unless you can find a very slim ic. to cool it id say use the stock hood and custom scoop it. not that hard of a task there. but harnessing it would be difficult. my suggestion is study the sti and use ideas from that.
i got a 90 pgt...but wish it was a mx-3 bp-t!
<img src="http://titan-racing.com/img/tr_site_logo.jpg" alt=" - " />
TsiMiata
Re: FMIC or SMIC?
Air to water works just as well as air to air. The downside is additonal parts- pump, front heat exhanger, water lines. But the intercooler can be much, much smaller than an air to air. Water absorbs heat 14 times better than air. So an air/water can be less than half the size and still remove the same amount of heat. The other nice thing about an air/water is if you can get a small tank somewhere you can chill the water with ice. That way you can get very, very cold intake temps for short periods which is great for the drag strip.<p>BTW- the electric power needed for the pump is very small. A 3 gallon per minute pump draws only 4 amps. If that amount of current draw bothers you don't turn on your radio.<p>[ September 04, 2003: Message edited by: TsiMiata ]</p>
91 Eagle Talon Tsi AWD *RIP*
ltjrunner
Re: FMIC or SMIC?
it would with the ****ty *** electicle system on mx-3's!! turn on your hazards and youll hear your exhaust go with the blinkers....also step on the brake and rpms will drop! <p>but i see ur point as to why its good and wouldnt actually create harm. something to think about.
Pearl-JapSpec
Re: FMIC or SMIC?
lol the brakes n the rpm's are funny
got that prob too...
Car Out Of Order For Now...
2 weeks In counting till re-incarnation!!
New G-Force Front Bumper!!
-_-_-_- Pics On Site -_-_-_-
http://members.cardomain.com/mx3_junkee
TsiMiata
Re: FMIC or SMIC?
Check your grounds and battery connections. you usually get those symptoms when those are dirty, missing or loose.
