Question about Jeff Abrams MX.
Shoalinfist
How much horse did he have before the turbo, and then after the turbo? Will his MSD ignition fit the 1.6L DOHC 4-cyl(I heard it could)? Also, he has a slide show on his site to view the install, but I can't get the pic to show; do I need a certain program?
David Coleman
Re: Question about Jeff Abrams MX.
You need powerpoint to view that slideshow I believe.<P>He had around 140whp before the Supercharger I'd assume.
David Coleman
ProtegeSTS
MSD ignitions are useless on NA applications, and not needed for a while with boosted ones. Factory ignition systems are just fine until you REALLY start to cram air in there.
-93 MR2
#129 E-stock
#129 E-stock
mazdamaniac
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Shoalinfist:<BR><STRONG>How much horse did he have before the turbo, and then after the turbo? Will his MSD ignition fit the 1.6L DOHC 4-cyl(I heard it could)? Also, he has a slide show on his site to view the install, but I can't get the pic to show; do I need a certain program?</STRONG><HR></BLOCKQUOTE><P>I dyno'ed at 146 HP pre SC, post swap.
