Corbeau Seats
Corbeau Seats
Hi guys. At this point I would like to replace my stock leather seats with a pair of black Corbeau A4s.. http://www.corbeau.com/brochure/A4.shtml I assume these are comfortable and fit in an MX-3.. Does anybody know? More importantly, I can't find a "Custom Bracket" for the MX-3 on Corbeau's page at http://www.corbeau.com/bracket.shtml ..I've seen MX-3s with Corbeua seats before - is there an alternative bracket (323/MX-6) or a custom bracket I can use? If so, are there any drawbacks to using them? Also does anybody know if there are any modifications needed for the seatbelt system, or will it still work fine with the new seats? Thanks, guys!
GS-R SE
Fixin's
- babyblueMX3
Re: Corbeau Seats
i beleive Darren Hyderman wrote somewhere in this site how he did his..maybe a little search and you could find it...i think he used the stock rails and modifyed them a bit
RIP 400whp ZE-T MX-3
Re: Corbeau Seats
Darren and I both performed the racing seat modification, search the appearance forum for racing seats and you will find it
<img src="http://images.cardomain.com/member_imag ... 3_full.jpg" alt=" - " />
Re: Corbeau Seats
Those look awsome. Thanks for the help! (BTW, is Darran the guy with the baby blue turbo MX-3 show car?)
GS-R SE
Fixin's
- babyblueMX3
Re: Corbeau Seats
no Darren had the black car but unfortunaletly he sold it
never heard of a babyblue trubo mx3...i mean i have a babybluemx3 but it ain't turbo ...
<small>[ January 26, 2004, 10:33 PM: Message edited by: babyblueMX3 ]</small>
Re: Corbeau Seats
Actually I know both of your guys's cars. I really like Darren's (spidie, right?) I've seen and read a lot about it and always thought it was very unique. I've also seen bits of your car all over for a while.. Actually, when I first got my MX-3 I wanted it to look pretty much like yours... (specifically) Thanks, btw
<small>[ January 26, 2004, 11:05 PM: Message edited by: mdavis ]</small>
GS-R SE
Fixin's
Re: Corbeau Seats
Escort GT 91-97 and 323 88-93 list the same part number and should fit our floor plan. That being the Corbeau brackets. I believe you may need the sliders as well. Probably cheaper to modify youe stock ones though. Check seat height carefully as well as the thickness of the bottom cushion. YOu might end up higher than you want to be.
Re: Corbeau Seats
Hmm... How do you know 323 brackets wil fit..? Also, just checking, but you're talking about the 2WD 323, right? (Apparently the 4 and 2WDs are different) Also, seat height is something I could still use some clarification on, even though I've read all the seat-related posts... I really, really, really don't want the seat to be any higher than stock... Any info? Thanks, btw
<small>[ January 26, 2004, 11:32 PM: Message edited by: mdavis ]</small>
GS-R SE
Fixin's
Re: Corbeau Seats
Mx-3 and 323 (2wd) and Protege and EGT share the same floor plan. It's built on the same chassis(BG). If you want to be absolutely sure go find any of the above and do some measurements. As far as height is concerned, I would again look at dimension specs for the seat that you are interested in and compare it to Mx-3 seat measurements that you can take yourself. Other thing is, if I were you I would definitely place my bottom into an physical seat for a test fit before buying it. Find a dealer that carries them or a person that has them installed. Some models are made for the track and may not be a great choice for the street, unless you are getting it for the track/strip.
Re: Corbeau Seats
Ahh. Thanks. Ya I was pronning on trying them first at a dealer.. Jeeze I hope they're not higher.. lol Well thanks again for your help. I will post pics/info when I get them (looking like about a month)
GS-R SE
Fixin's
- monty73741
Re: Corbeau Seats
i know that the same part number for 91-96 escort fit the mx-3
Jason Danaher
Please Help Support MX-3.com
Re: Corbeau Seats
Thanks!Originally posted by monty73741:
GS-R SE
Fixin's
Re: Corbeau Seats
when i put racing seats in my mx i just used the stock seat brackets i had to drill a new hole for the rear bolt but other then that they bolted right up only porb i ran into is the seats sit a little higher then the stock seats did anyone know a way to lower them a little i dont have much room between the seat and the stearing wheel
Re: Corbeau Seats
hey john what did u do to ur door panels to make em loook white where the carpet is?
94 mx3 gs (sold)
92 Mitsubishi Eclipse GSX(14.3 @ 99.08- almost completely stock)
Re: Corbeau Seats
lol www.mazdamaniac.comOriginally posted by BucktownMx3:
GS-R SE
Fixin's
