Corbeau Seats
mdavis
Corbeau Seats
Post by mdavis »
Hi guys. At this point I would like to replace my stock leather seats with a pair of black Corbeau A4s.. http://www.corbeau.com/brochure/A4.shtml I assume these are comfortable and fit in an MX-3.. Does anybody know? More importantly, I can't find a "Custom Bracket" for the MX-3 on Corbeau's page at http://www.corbeau.com/bracket.shtml ..I've seen MX-3s with Corbeua seats before - is there an alternative bracket (323/MX-6) or a custom bracket I can use? If so, are there any drawbacks to using them? Also does anybody know if there are any modifications needed for the seatbelt system, or will it still work fine with the new seats? Thanks, guys!
GS-R SE
Fixin's
babyblueMX3
Re: Corbeau Seats
Post by babyblueMX3 »
i beleive Darren Hyderman wrote somewhere in this site how he did his..maybe a little search and you could find it...i think he used the stock rails and modifyed them a bit
RIP 400whp ZE-T MX-3
Johns93GS
Re: Corbeau Seats
Post by Johns93GS »
Darren and I both performed the racing seat modification, search the appearance forum for racing seats and you will find it
<img src="http://images.cardomain.com/member_imag ... 3_full.jpg" alt=" - " />
john kilfoyle .:. mx-3 fanatic
http://www.cardomain.com/id/johnmx3
mdavis
Re: Corbeau Seats
Post by mdavis »
Those look awsome. Thanks for the help! ;) (BTW, is Darran the guy with the baby blue turbo MX-3 show car?)
GS-R SE
Fixin's
babyblueMX3
Re: Corbeau Seats
no Darren had the black car but unfortunaletly he sold it
never heard of a babyblue trubo mx3...i mean i have a babybluemx3 but it ain't turbo ...
<small>[ January 26, 2004, 10:33 PM: Message edited by: babyblueMX3 ]</small>
mdavis
Re: Corbeau Seats
Post by mdavis »
Actually I know both of your guys's cars. I really like Darren's (spidie, right?) I've seen and read a lot about it and always thought it was very unique. I've also seen bits of your car all over for a while.. Actually, when I first got my MX-3 I wanted it to look pretty much like yours... (specifically) :) Thanks, btw ;)
<small>[ January 26, 2004, 11:05 PM: Message edited by: mdavis ]</small>
GS-R SE
Fixin's
Taras
Re: Corbeau Seats
Post by Taras »
Escort GT 91-97 and 323 88-93 list the same part number and should fit our floor plan. That being the Corbeau brackets. I believe you may need the sliders as well. Probably cheaper to modify youe stock ones though. Check seat height carefully as well as the thickness of the bottom cushion. YOu might end up higher than you want to be.
Taras
'92 GS Gray ZE
'05 Gixxer 750
MxWest VP
www.mx-west.com
mdavis
Re: Corbeau Seats
Post by mdavis »
Hmm... How do you know 323 brackets wil fit..? Also, just checking, but you're talking about the 2WD 323, right? (Apparently the 4 and 2WDs are different) Also, seat height is something I could still use some clarification on, even though I've read all the seat-related posts... I really, really, really don't want the seat to be any higher than stock... Any info? :) Thanks, btw
<small>[ January 26, 2004, 11:32 PM: Message edited by: mdavis ]</small>
GS-R SE
Fixin's
Taras
Re: Corbeau Seats
Post by Taras »
Mx-3 and 323 (2wd) and Protege and EGT share the same floor plan. It's built on the same chassis(BG). If you want to be absolutely sure go find any of the above and do some measurements. As far as height is concerned, I would again look at dimension specs for the seat that you are interested in and compare it to Mx-3 seat measurements that you can take yourself. Other thing is, if I were you I would definitely place my bottom into an physical seat for a test fit before buying it. Find a dealer that carries them or a person that has them installed. Some models are made for the track and may not be a great choice for the street, unless you are getting it for the track/strip.
Taras
'92 GS Gray ZE
'05 Gixxer 750
MxWest VP
www.mx-west.com
mdavis
Re: Corbeau Seats
Post by mdavis »
Ahh. Thanks. Ya I was pronning on trying them first at a dealer.. Jeeze I hope they're not higher.. lol Well thanks again for your help. I will post pics/info when I get them (looking like about a month)
GS-R SE
Fixin's
monty73741
Re: Corbeau Seats
Post by monty73741 »
i know that the same part number for 91-96 escort fit the mx-3
Jason Danaher
Please Help Support MX-3.com
mdavis
Re: Corbeau Seats
Post by mdavis »
Thanks! ;)
GS-R SE
Fixin's
tonguefreek
Re: Corbeau Seats
Post by tonguefreek »
when i put racing seats in my mx i just used the stock seat brackets i had to drill a new hole for the rear bolt but other then that they bolted right up only porb i ran into is the seats sit a little higher then the stock seats did anyone know a way to lower them a little i dont have much room between the seat and the stearing wheel
BucktownMx3
Re: Corbeau Seats
Post by BucktownMx3 »
hey john what did u do to ur door panels to make em loook white where the carpet is?
94 mx3 gs (sold)
92 Mitsubishi Eclipse GSX(14.3 @ 99.08- almost completely stock)
mdavis
Re: Corbeau Seats
Post by mdavis »
lol www.mazdamaniac.com
GS-R SE
Fixin's
Return to “Appearance”
