I have heard that there is a recall for the seatbelt retractors. Anyone have any info on that. I tried to search for some info but came up flat. The driver's side electric window lift doesn't work. I discovered that the motor is fine, but the gear is badly worn. Can anyone help with part number for just the gear? Is it available, gear only? How about availability for the whole assembly?
Where is a good place to get rear hatch lift cylinders? Any suggestions on where to buy a clutch for a good price.
Automatic seatbelt recall? Elect motor gear?
lakersfan1
Re: Automatic seatbelt recall? Elect motor gear?
There's a lifetime warranty on the automatic safety belt system in the MX-3. Take it to a Mazda dealership and tell them you know about the recall/warranty.
- mitmaks
ya, i have same problem, driver's side wont latch completely and like stops in middle... and ive thought about taking it to mazda dealer, but i was lazy and now its winter, so i guess ill wait till spring. What if i come there and they'll wanna charger me?
Johns93GS
They cant charge you as far as I know... since its an open recall on the life of the car. The only reason the recall is open forever is because it is on the restraint system, and you could die because of their mistake...
Just keep pressuring the high-ups at the dealerships, and they will do it for you
