fast blinkers and also resonator
Tman
Re: fast blinkers and also resonator
Post by Tman »
Where can the ground-wire for the blinkers be located? And if i cut the ground-wire could there be any negative effects?
R.I.P. September 25th @ 2:55 p.m. - 93 Mx-3 RS :-(
Tman
Post by Tman »
*bump*
antwawn
Post by antwawn »
TO visual...i dont know if 94 cars are different to 92 mx3's but mine goes from y pipe TOOO THE CAT...then resonator then muffler.....the cat looks like a another muffler the the resonator does not...but i dont know if 94 are this way???
Shades
Post by Shades »
Resonator is located about the middle (front to back middle) of your car... just before the muffler... most posts I've seen say don't take it out, it's too loud. It looks like a little bulge in the pipe.
"Do it ONCE, do it RIGHT!"
monty73741
Post by monty73741 »
pull out your turn signals & cut the black wire<BR>jason
Jason Danaher
Please Help Support MX-3.com
Tman
Post by Tman »
I cut the ground wire, and now the front blinkers are REALLY really dim...anything i can do about this?
Tman
Post by Tman »
<p>[ September 08, 2002: Message edited by: Tman ]
Paragon
Post by Paragon »
ebucks - you can mount your relay under the hood, just enclose it in a ziploc and tape it shut.
Return to “Appearance”
