Clutch :(
- solo_ryder
Re: Clutch :(
Sweet ok, how much is a bradied steel line?
Re: Clutch :(
Like $12 or so.
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
- solo_ryder
Re: Clutch :(
Awesome, i'll get that as well, I started my car today and it sounds like its metal to metal, does this mean that raw material is scraping up against my flywheel? if so should i get it resurfaced?
Re: Clutch :(
Always resurface your flywheel when putting in a new clutch
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- solo_ryder
Re: Clutch :(
K awesome looks like i am all set, one more question, if i did a 2.5l KLDE swap in the near future would this clutch flywheel combo hold up?
Re: Clutch :(
Yes, since the clutch is from a KLDE.
91 Eagle Talon Tsi AWD *RIP*
- bmwm3guy
Re: Clutch :(
dont even bother buying a clutch alignment tool... Its 30$ you dont need to spend. Align it by eye and if the tranny goes on, you got it. If not, try aligning it again. Ive done two ZE swaps and both times I got it on and aligned first shot by eye.
- solo_ryder
Re: Clutch :(
Yea but the clutch i am ordering comes with the pressure plate and the throwout bearing and i am pretty sure it comes with the alignment tool, so we'll see, BTW the clutch/tranny is ont he drivers side right
- solo_ryder
Re: Clutch :(
Well i got my PGT clutch in today along with the throwout bearing and presure plate, all thats left to do is rebolt up the tranny and the CV's plus all the wiring and intake etc. Looks like everything gonna be ok, I couldnt resurface the flywheel though because I couldnt get the blots undone there were torqued on there, but the flywheel looked really good, no hot spots or grooves so i'll keep ya'll posted.
Re: Clutch :(
Just a freindly reminder, without resurfacing the flywheel you will more than likely get a studder when engaging the clutch. It is a risk your taking that I've learned the hard way not to take.
After all that work I'll hope you get lucky.
Andy P. 93 GS
Andy P. 93 GS
- solo_ryder
Re: Clutch :(
hey, I just finished putting the clutch in and getting an alingment, the reason I had a shudder before was because of a combination of the pressure plate and the throwout bearing, the throwout earing is what made my clutch stop working in the first place cause it blew, I didnt resurface th flywheel because i was really smooth, plus we could get it off, and now the clutch feels good, light pedal and no shuddering, only one problem now, my cv axle is causing vibration on the drivers side upon acceleration, and cornering, we assume its not in proporly.
Re: Clutch :(
Man that is definatly a chance I wouldn't have taken. But sounds like you might have gotten lucky. After all that work to take the tranny off. That one thing that is worth the $25.
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
Re: Clutch :(
when you dont resurface flywheels...even the minimal difference between the new clutch an the flywheel will cause your clutch to wear out faster..thats why they got that "break in" period...so that the clutch can sit properly eith the flywheel..in your place...um even if its even..theres no way that the flywheel is going to be the same as the clutch. Premature wear here it comes. WEll of course that all depends on how yopu drive and how long ago the flywhee was resurfaced..but since your ****ch was bad im assumoing it was heating up the flywheel pretty bad. i think its worth the 25 dlls to resurfaec it. over here it costs me around 10 ![Smile :)](./images/smilies/icon_smile.gif)
-hec
Re: Clutch :(
hmm thats interesting.. i must have misspelled clutch and the server thought it was that female part...cli... bleh that ..my bad
wow im the master at typos.
-hec
- solo_ryder
Re: Clutch :(
yes i agree i could of resurfaced it for 15$, the problem was we couldnt get the dam thing off. and no the flywheel was no being abused, there was no hot spots on it at all, it was resurfaced witht the last clutch install, But w/e the clutch is in now and it feels smooth. thx for everyones help!
