water pump replacement
- mitmaks
what are step by step to change water pump on k8, this one guy wants $250+tax and probably will replace timing belt which will be extra. I think thats ridiculous price esp if I can do it myself, so how you do it, anyone got manual pages to change it, please help
mitmaks@yahoo.com
mitmaks@yahoo.com
Re: water pump replacement
If you've got Microsoft Word,
http://odin.prohosting.com/bblades/leskatimingbelt.zip
Unzip, read, enjoy.
Unzip, read, enjoy.
- mitmaks
thank you for zip, any other tips/tricks guys, what else besides water pump ive gotta change?
friction bearing, water pump seal, timing belt tensioner (but i think these are all listed in that FAQ..)
1996 Black GS 1.8l w. PRM intake and custom exhaust, zx2 strut conversion and Intrax springs, B&M short shifter and SRD bronzoil bushings, Ractive front and rear strut bars, Raxles axles, ESpec clear markers and front signals w. driving lights, Alpine headunit with 10" JL sub, jbl amp and front speakers.
Awaiting installation: Magnecore 8.5 Comp. ignition wires, ACT Stage 1 clutch w. SS clutch line, Outlaw phenolic spacers.
- mitmaks
timing belt tensioner has to be changed only if replacing timing belt i believe, water pump can be replaced without messing with timing belt or so ive read in that manual
It only has to be replaced when it goes bad, but it would make sense to replace at every timign belt change, as they seem to be able to last a little longer than the normal 60K belt interval, but not quite two belt intervals. Since our cars are non-interference, I almost think it'd be better to extend your timing belt change interval until the tensioner starts going.Originally posted by mitmaks:
- fry_81
only $250? i called mazda when i did my waterpump and they quoted me $650 plus tax. so i did it myself. i couldnt get the pump off without taking the timing belt off though, i think the belt blocks it.
1994 5spd GS Parts Car For Sale 800obo. e-mail for details. fry_81@hotmail.com
- mitmaks
was also told i have to take out engine to replace pump is that true?
absolutely not..
$250 is super cheap especially if it includes the water pump. You have to pull the the t-belt to change the pump. IF you've all ready got it apart that far it's no extra work to replace the belt.
91 Eagle Talon Tsi AWD *RIP*
Where'd you get that crap from?Originally posted by mitmaks:
- fry_81
take the engine out? no no no. if a mechanic told you that they are trying to scam you. theres enough room to work once you take off the belts and hoses. you can probably do it in a weekend.
I found it a bit easier if I took out the right motor mount. Gave me better access.Originally posted by fry_81:
Mike
you have to take the motor mount off cuz one of the motor mount bolts goes right throught the water pump.(If it didnt it would be really easy) and you dont have to take off the timing belt, just takes some manuvering..
- bmwm3guy
wtf?Originally posted by Ebsouljah:
![Confused2 :confused2:](./images/smilies/confused2.gif)
