KLZE Motor
KLZE Motor
On the back of the motor a friend putting in there is no place to hook the polution up like there is on the one thats being taken out. Actually its not drilled for it. The question is Does it matter if its hooked up? If its not whats the worst that can happen?
Can someone get back to me ASAP cause the motor is being put in tomorrow.
Thanks
Steve
Thanks
Steve
Re: KLZE Motor
Do you have emissions tests in your country? If so, do they test for NOx?
Re: KLZE Motor
The opnly time a car get tested/inspected here in Canada(Newfoundland) is when the car is being sold. As in testing for "NOx"......i' guessing you mean NOS. No they dont.
Steve
Steve
- papa roached
Re: KLZE Motor
NOX is one of the things that come out your tail pipe
Re: KLZE Motor
as far as i know we dont have that testing here.
I'm wondering about this because the polution manifold is cracked on the original motor and is leaking. WE wanted to know if we can get away with putting the other one on from the ZE and not have any problems.
- babyblueMX3
Re: KLZE Motor
the thing you are refering to is probably the egr...you can use your manifold that doesn't have it...BUT if you don't got a ze ecu you'll constantly have a cel (check engine light)..
RIP 400whp ZE-T MX-3
Re: KLZE Motor
If your emissions tests do not test for NOx, then you don't need your EGR really to be hooked up, though they may expect the components to be there for visual inspection. It will pass the CO% and HC portions of the emissions just fine without a functioning EGR.Originally posted by JustAGuest:
Re: KLZE Motor
im from newfoundland to, and they dont have emissions tests or any type of test like that. Im doing a ze swap sometime soon and dont plan on hooking up the egr.
Re: KLZE Motor
Other than the CEL will there be any other issues?
Run rich/lean? Poor idel?
Or anything else
Or anything else
- babyblueMX3
Re: KLZE Motor
nope everything should be fine
- PATDIESEL
Re: KLZE Motor
I pass emissions in Georgia with out the EGR better than the last time that I passed with the K8. The ZE runs pretty clean.
